#1
Back into the blogs section. Happy to be here
... Thread will be dedicated for all the crap(Including pics(All shots with be done with HDR with a Nikon D40), and detailed storys, builds, and what not) that goes on in my life , also with the additional last few touches to the Accord . Than onto bigger, better things in life . If you would like to leave a comment.. Just rep me or PM me...Enjoy. To all who have had some kind of help to my life...Special Thanks... -Family -Katelyn(The Significant One, and Happy Helper) -Tag (Satans little lazy bastard, Love Child) -Nikon -JJ(brwloco) -Kevin(tsiguy94) -Clark(Clark94t) -ImportAtlanta.com -SupraForums.com -ClubLexus.com -ClubNA-T.com -Fred(craaazy) Specs On On Going Project Car: 92' Black SC300 Onyx Black Exterior: 94 FD Wheels 16x8 Front - Dunlop Tires 225/50/16 Rear - Mickey Thompson ET Streets 255/50/16 Interior: Stock Tan Interior Black Sparco Monza Seats (D&P) Motor: Fully Rebuilt 1JZGTE (2500cc Twin Turbo) New Gaskets, Belts, and Seals New Rear Sump Oil Pan Auto Tranny TT Motor Mounts TT Transmission Mount TT Throttle Cable TT Denso Fuel Pump Driftmotion Intake HKS Front Mount Intercooler HKS Fuel Cut Defencer HKS Downpipe MAP ECU 1
__________________
#2
So successful day to get the seats installed into the car
, it was much easier since I knew what I was doing this time around... Plus it was even easier with the help of the girlfriend(Yes she likes to get down and dirty working on cars of course ).Pic on the bottom of the seat... It just looks cool. ![]() Everything laid out and ready to be installed. ![]() Random Pic...Just messing with the Cam ![]()
__________________
#3
So some how I lost one of my memory cards and the installation of the seat pictures are missing. With help with the girlfriend, it took less than 1 hour to do everything(Compared to 2 hours).
-Brackets are bolted up(Had to drill custom holes to fit the way I wanted to) -Cleaned out the whole car(Unbolted unnecessary pieces, vacuumed, and cleaned the carpet) -Bolted in seats -Bolted in Harnesses Final Pic(Not the best shot) Corbeau A4 Seats(So Comfy) Corbeau 4 Point Harnesses With Pads (2 Inch) Corbeau Brackets ![]() Stayed tuned for new suspension parts, and the move into the new apartment.
__________________
#4
School is almost up.. Getting ready to work more and more into the winter break.
The final date for the moving date is the 12th... Expect to see some paint and pre-insect killings(Just in case, since girlfriend hates bugs)... New tires have come in, currently waiting for the front two. Sizing wont be different it will still be 234/45/17 in the rear, and 225/45/17 in the front.. Yes its an Accord with a staggered setup(7.5F 8.0R).Tires are BFGoodrich G-Force Sport... Good Shit for a cheap price.
__________________
#5
Just got the rear tires mounted for 2 of the rims. They look good, awaiting the front two which is expected to be in by Friday. Should have another update on Monday, in which that is when the tires will be on and the rims will be on the car. One pic real quick... Looks pretty cool.
![]() ![]() Moving boxes are some what starting to build up. The Excitement.....
__________________
#6
All tires are here, the front ones wont be mounted until spring time or in a time I need them. Im just going to rock the Yokohomas in the front since they are crap tires too me, plus the fact that I need a camber kit for the front.
Front camber kit is coming in, just bought one from SPC. ![]() Rear camber kit is still debated. Since i dont need one that bad. ![]() New tires will probably be mounted once the camber kit is in. ![]() Pics in soon, Moving day comes in 4 days....
__________________
#7
Got some suspension adjustments done for the night...
![]() Advans are back on the car.... Pics of progress, final shot is for another day. ![]()
__________________
#8
Finally moved into the apartment. Great girl, great place...Now for a new project. As some may know or have seen the Accord has been parted out. Literally everything. Buy everything... I need it gone to fund the new project.
I am keeping the Accord for a daily. Gotta love the gas mileage. New project car will commence the first day of Spring, but until then I will be buying parts for the car so keep checking out the blog for updates. Last and final pic...
__________________
#9
For any good project requires a lot of research...
1jz-gte factory specs- Displacement : 2491cc Type : Twin Turbo Inline 6 Cyl Valvetrain : Belt driven DOHC, 4 valves per cylinder Fuel System : TCCS EFI, Premium Unleaded Ignition System : Direct fire ignition Combustion Chambers : Pent Roof Compression Ratio : 8.5:1 Bore x Stroke : 86 x 71.5 Peak Power : 280PS (206 kW) @ 6200rpm Peak Torque : 37.0 kgm (268 lb ft, 363 Nm) @ 4800rpm Fuel Consumption : 210 g / PS*h @ 2000 rpm Dimensions (LxWxH) : 860 x 670 x 665 mm (MTM) : 845 x 670 x 665 mm (ATM) Weight (complete) : 217kg Turbos : CT12A (2x) Compressor wheel : 37/54mm Turbine wheel : 52/42mm Boost : 0.60-0.69kg/cm2 (8.5 - 9.8psi) Fuel Injectors : 380cc/min high impedance Intake cam timing (o-c) : 3° BTDC - 41° ABDC Exhaust cam timing (o-c) : 46° BBDC - 2° ATDC Camshaft duration : 224 (in) 228 (ex) Valve clearance cold : 0.15-0.25mm (in) 0.25-0.35mm (ex) Spark plug : ND PK20TR11 / NGK BRK6EKPB11 Plug gap : 1.1mm (limit 1.3mm) Base Ignition timing : 8-12 BTDC (jumper TE1,E1) Idle rpm : 600-700 Engine Oil : SAE 10W30, API SH First of all, let me inform you that the #1 myth about the 1jz is NOT true. Parts are easily accessable here in the states. Soarer (jzz30) 1jz-gte swap into a Lexus SC300 Parts needed: (some may not come w/ your clip or engine set... Supra is refered to as the MKIV) 1JZ-GTE Soarer engine 1JZ-GTE Soarer ECU 1JZ-GTE Soarer trans (if prefered) Soarer or Supra side mount intercooler/pipes Supra Upper/lower radiator hoses (if the ones w/ your engine set are cut) Supra TT throttle/cruise cable Soarer/Supra Igniter A spool of 18g wire (to extend the harness) USB Cable (to shield the knock sensor wires when extending them) Heatshrink/Solder New motor mounts (recommended) MSD Tach adapter (for the tach) 330ohm resistor (for the temp gauge) HKS Fuel cut defencer (or similar) Greddy speed limiter cut controller (or similar) Supra TT/Walbro fuel pump New plugs (NGK3330's .025-.030 gap recommended) New Timing belt (Isuzu Trooper 4 cylinders 2.6 liters, or a Greddy for 5 times the cost) Necessary fluids The swap is pretty much straight forward. It will bolt up to the SC300 auto or manual trans. Or you can opt to use the soarer auto or soarer r-154. First thing I would do it extend the harness (about 18 inches). You dont "have" to extend the ECU plugs but for accessibility reasons in the future such as wiring an s-afc, e-manage etc, I would recommend to. Take off the front bumper, radiator, condensor. This makes it easier to pull the NA motor our and put the 1jz in. The hood should come off too. Of course you know to unplug your stock harness and pull it through the firewall and unplug the necessary things that need to be unplugged. (atleast I hope so if your attempting to do a motor swap) so ill skip all that... I would unbolt the a/c compressor and leave it to the side so you dont have to re-charge the a/c system. Thats your choice. Pull the NA motor out and drop the 1jz in. The 1jz will bolt up to the stock motor mount locations on the SC300 and on the SC400. It will go in with the downpipe connected (just takes a little more time). Bolt it up, route the harness through the firewall and everything plugs right in. The plug that goes down to the power steering rack&pinion from near the alternator needs to be lengthened a few inches due to rhd/lhd swap. The SC300 fan shroud will work w/ the 1jz fan. Remove the plastic cover on the inside of the pass. fender so the smic piping can go through there. Take out the 2jz-ge coil. Bolt in the 1jz igniter (it goes on the drivers side shock tower). The fuel pump takes 2 seconds to do. The less gas in the car the easier it will be. Pull off the bottom part of the back seat (1 clip on each side). Unbolt the 3 bolts that hold the seat back and slide the seat back up and pull it out. Use a small wedge tool or flat head and take the round cover off. Then unscrew those bolts to reveal the fuel pump. If using the Walbro, you will have to cut the wires that go to the pump and resolder it to the harness that comes w/ the Walbro. Your also gonna need to gently bend some of the fuel lines to get the rubber line to fit correctly. After that everything goes back together. Make sure the tach adapter is wired in or else you wont get a tach reading. The 330omh resistor for the temp gauge goes behind the intrument cluster on the yellow wire w/ the green stripe. You will probably get an airbag light on. Im not sure why it comes on but I just took the bulb out. Thats pretty much it to get the 1j up and running. Im sure im missing a few things so just ask and ill probably remember...... Im using the Soarer Torsen rear end w/ my set-up. I highly recommend using some sort of LSD when doing this swap. One wheel wonders are no fun. You can use the Supra TT rear ends, but the flange where the d/s connects to the diff needs to be swapped w/ a supra one. For fluids im using mobil1 10w-30 full synthetic, toyota coolant w/ distilled water and a bottle of water wetter, toyota type-iv trans fluid. You might notice that your car seems to run a little hotter than the NA when you open your hood after a drive. Its normal. Most of the jz-gte's tend to seem a little warm under the hood. Im using NGK plugs -7(6097 i think) gapped at .028. .030 works if your on stock boost but you want to close it up some if you plan on running higher boost. When doing oil changes I use the Supra oil filter. Part #-90915-YZZD3. There is also another oil filter I have that works. It's about an inch shorter than the one I use, but the part# for that is- 90915-YZZD1 If you are doing the stock swap, stock boost is around 10psi. The twins are ct-12a's therefore the blades are ceramic. If you didnt know, ceramic blades dont like high boost. The highest boost I run on the street is around 16psi (1.11bar to be exact). Most of the Aussies dont push much if any over that as the turbos tend to give w/ all that boost. I have however hit 21 psi in first gear one time just seeing how high it will climb and blew an intercooler pipe. That was a one time only type of thing though. hehe. When upgrading the 1jz, 95% of the 2jz-gte parts are usable. All but one or 2 of the sensors are exactly the same as the 1jz (what a coinsidence). The basic bolt on part mostly interchangable. 2jz-gte parts that need modding to work on a 1jz: Catback exhaust downpipes Turbo manifolds (the bolt flanges) Intake manifolds (bolt flanges again) radiators (mainly fluidyne) injectors valve cover gasket 2jz-gte parts that work w/ out modding: Pulley's including the crank pulley Waterpump's internals intakes intercoolers drive belt alternator a/c compressor p/s pump strut bars suspension components wheels (mkiv offsets fit pretty well on the SC) spark plugs ignition coils oil filters Hope this helps for anyone who is trying to follow or attempt such a project.
__________________
#10
So days of hard work and patience collecting parts with lots of research a new project is slowly emerging.
If it isn't obvious already the project is an SC chasis with the 1JZGTE swap. The swap will be all or mostly bolt ons. A basic BPU++ SC300. Pictures will be in once I get the new camera... Also I got a new little rug-rat... Tag.
__________________
#11
So with good news and financial situations going pretty well parts have been coming in to perform the swap. With the economy down scouraging for cheap reliable parts is easier to come by. So on to the pics with some of the parts I have already obtained. Enjoy...
Pair of Mickey Thompson on RX-7 Wheels... Specs: RX7 Wheels are 16x8 and the tires are 255/50/16. ![]() ![]() HKS FCD ![]() MAPECUI With Harness Note: Pretty much will be using MKIV base map to run the car until I can get it tuned. ![]() Thanks for looking. More updates soon.
__________________
#12
More shizzle came in..
HKS DP Made for the MKIV modded to fit SC300 with a 1JZ. HKS FMIC with piping. Piping is going to be powdercoated. More to come with custom JDM MODS!!! Also picking up a shell Sunday. Stay tuned for more updates.
__________________
#13
Finally bought an SC300. Its an 92 black on shitty tan(which will be soon ditched). Got it for a good price, especially since the exterior is really nice. On to the pics.
![]() ![]() First I thing I did was slapped on the DR's and washed her. ![]() ![]() Started detailing her for a bit. Nice ![]() ![]() Look for more updates. Interior is coming out with new ones coming in. Also a motor should be ready to drop in.
__________________
#14
Started removing the front bumper, drained all the fluids and started to remove the radiator. Pics will be up in the following week.
Some really good guidelines in removing all the above parts... Link should help any others that need to remove the front bumper. http://www.lextreme.com/scbumper.html
__________________
#15
Bumper off... It looks pretty cool.
![]() Stock motor... ![]() Radiator out... ![]() Ewww Rust... Going to be side project in order to get rid most the rust. Possible respray.
__________________
#16
This time I brought the pup with me... He was no help.
![]() ![]() Katelyn pulled the interior, most of the seats are trashed, and were going to try and clean the carpet as much as possible. If the carpet comes out well were going to keep it. ![]() ![]() Ewww... Stains out of my ass!!!! Its literally disgusting. But with some clean good chemicals and lots of scrubbing. It should look good.![]() ![]() ![]() While the girlfriend was pulling the interior, I pretty much was disconnecting the harness and prepping the motor to be pulled. ![]() No more intake. ![]() ![]() Stay tuned for more updates.
__________________
#17
Finally pulled the nasty ass interior.
![]() ![]() ![]() After a few hours of cleaning the carpet(3 Cans of stain remover, and a steamer) at the same time when the the girlfriend was removing all the shit that was under the carpet. I received and mounted some new goodies. DriftMotion.com custom intake for a 1JZ/2JZ. (I dont really like the blue )![]() Also got a chance to mount the FMIC... ![]() And for the possible final carpet...
__________________
#18
Finally was able to pretty much finish the interior. Pretty much have all the stains gone. Also installed the new Sparco seats(Thanks to Clark). Used Supra bracekts, which fit like a charm.
Just need a few touchup parts... If anyone has some I have cash in hand to purchase. Tan Steering Wheel Tan Shift Knob Tan Brake Boot The motor is pretty much ready to be pulled out. PS pump and AC pump pulled 98% of the lines had been pulled. Anyone want a motorset?
__________________
#19
Went up to Dahlonega for dinner with the Girlfriend. Took some town pics and pics of the girlfriend too. Nice place.
![]() Girlfriend planning on if to go or not. ![]() 45 Min Drive...Blah ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Night Vusion!!!!
__________________
#20
Finally finished the interior. Complete new panels with new trims. And new rear seats...No pics of the rear seats, but one pic of the panel.
Finally got my Soarer Auto Driveshaft. SO FREKING JDM MONSTER.!!!
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
